Author Topic: CVT roller weights and clutch and belt replace tool  (Read 1091 times)
« on: June 05, 2013, 11:50:56 PM »
Found this video for roller weights replacement.
As you can see, you can use this impact wrench to remove those nuts for roller weight replacement, or belt replacement, or clutch work on your CVT scooter.
Youtube video....
Very  interesting comment on this  tool which was used to remove those nuts on a GY6 engine.( our LIKE apparently is a GY6 Engine)
Also see the advert for this tool. Low price, works off car cig. outlet...can be used for those few times we will be working inside that CVT cover over the life of our scooter. Beats the heck out of jamming tools into the sprocket, stuffing rope into the spark plug hole to jam against the piston as it tries to rise, or that piston stop that is htreaded into the plug hole to jam the piston , all those things are used to break the nuts loose - as some videos show.. Probably work just fine - but I'd be a lot more comfortable using the proper tool on my expensive scooter engine.
« Last Edit: June 06, 2013, 12:07:37 AM by Stig »
vespa50sp
Re: CVT roller weights and clutch and belt replace tool
« Reply #1 on: June 06, 2013, 03:30:46 AM »
I used a Harbor Freight electrictric impact wrench. Under $50 with the easily available 20% off coupon. You'll need the correct socket though. Also cheap at Harbor Freight.
