Author Topic: Electrical problem  (Read 1217 times)
Jimmybrid
Electrical problem
« on: June 06, 2013, 12:34:30 PM »
Hi all I have a issue my main fuses 15 amp will blow after riding 20 min or so. It's not the fan. Any ideas. Thanks
Sorry it's a grand vista 250.
windwheeler
    • WindStrom windshields
Re: Electrical problem
« Reply #1 on: June 06, 2013, 02:09:00 PM »
That is a tough one.
Have you tried if it does it too when you let it idle for 20 minutes?  Reason asking, trying to figure out if it is related to vibration from the road, or just heat related, so that something shortens out.
Just a wild guess,  the thermo element of the choke?
Jimmybrid
« Reply #2 on: June 06, 2013, 07:08:46 PM »
yes i let it idle and it didnt happen. But today as i road it right befor it went out the battery light came on.
MaryK
« Reply #3 on: June 06, 2013, 08:39:19 PM »
The main fuse (from the battery) is a 30A according to my manual (service manual Page 16-1).
There are also 2 10A fuses and 2 15A fuses.
Fuse A  30 A  Charging system
Fuse B 15A  most lights, horn
Fuse C 10A   Ignition
Fuse C 10A  Fan motor
Fuse E 15A  Headlight and luggage box.
If it is E, then I  would look for a grounded wire to the luggage box light.
scoot safely
New Rider in 2010
2009 GrandVista 250
Jimmybrid
« Reply #4 on: June 07, 2013, 12:21:15 PM »
You would think it would be the 30 amp how ever in the manual it shows the 15 amp as the main.
It is the seconded fuse from the front. When the fuse blow out the bike stays running, but you loss all electronics, light dash blinkers and such.
windwheeler
« Reply #5 on: June 07, 2013, 01:24:02 PM »
Thanks MaryK for listing the fuses.
Jimmybird: so is it the 15A that blows that also has the horn but not the headlight?
