Author Topic: Techron, just a random observation.  (Read 2272 times)
jwalz1
« on: June 06, 2013, 08:00:48 PM »
Bought a Downtown that was a left over last year, I think it is a 2011, don't remember.  Anywho....it has had an intermittent problem.  It would sometimes be really boggy.  It would not kick into that sort of "second gear" the engine does when it gets past about 15 mph then takes off with a larger surge, it would just accelerate weakly.  This would happen periodically and I tried taking off the gas cap to see if there was some vapor lock and reset the throttle setting with the standard procedure.  I used some seafoam in the gas.  But it would still happen on occasion and then seem to go away on its own for no reason only to reappear.
It occurred to me that since this was a leftover it probably sat for a year with gas in the tank, most likely with some Minnesota ethanol and perhaps there was some crud in the fuel system.  I use techron concentrate in my cars with very good results and put in a healthy dose with a full tank of fuel.  Within a very short time it ran like a beast and has displayed more power than its first few miles.  I have not had the bogginess come back since I used it and suspect that the techron did the trick.
I read that this is one of the most aggressive and effective fuel additives money can buy and seem decent results in my car but it was like night and day after a couple days and 20 miles of it in the scooter.  If you have any intermittent problems and suspect any crud in the fuel, give it a try.  It seems to have cleared up a problem in mine that sea foam would not.
MotoRandy123
  • Lets Ride!
Re: Techron, just a random observation.
« Reply #1 on: June 06, 2013, 08:26:48 PM »
Techron used to be the best stuff on the market but I read somewhere they
removed the PET from it so it's not as good anymore. I'll have to give it another
try as it worked so good for you!
mnpugdog
« Reply #2 on: June 07, 2013, 08:34:22 PM »
jwalz, did yours almost have a surging in the lower RPM's? Mine also sat for a while and I also thought it was the Minnesota corn gas too and added sea foam. I think I will try the techron now and see if it helps.
jwalz1
« Reply #3 on: June 08, 2013, 08:07:44 PM »
Surging during accel or surging at idle?  I think I have read about people have a surging at idle problem but have not experienced that.  That sounds more like a vacuum leak to me but I would bet fuel system problems can have all kinds of symptoms.  Techron might not help but won't hurt.
ophelia
« Reply #4 on: June 09, 2013, 06:12:08 AM »
Gumout Regane still has those PEAs.
2011 Kymco Downtown 300i
mnpugdog
« Reply #5 on: June 09, 2013, 02:43:39 PM »
It's during acceleration. I'll try the Techron and still make an appointment at Scooterville to have them look at it too.
Rbt Jean
« Reply #6 on: September 11, 2013, 02:48:20 PM »
You might want to try using a higher octane fuel for a while. I’ve done that in cars.
mnpugdog
« Reply #7 on: September 11, 2013, 03:43:30 PM »
I have been using the high octane. I did recently tried adding Stabil ethonol additive and it seems to help some. But with the issue still going on and the engine codes coming up I'm going to need the dealer look at the settings on the ECU.
