Author Topic: Scooter batteries  (Read 2367 times)
kingkymco125
Scooter batteries
« on: June 11, 2013, 08:22:29 PM »
Hello everyone:
I was at my local scooter dealership here in Vegas and I spoke to the mechanic about the battery. Temps have already reached into the extreme one teens. I ask the mechanic about the life of the batteries for the bikes and he told me they could last up to 4 year which impressive for the desert. I always thought it was the hot dry sun which destroys batteries, but it is not. He told me it is not keeping the batteries fluids up to date. My mechanic told me that everyone less their batteries dry out. This is why one is lucky if any battery really lasts beyond 2 years. I am so happy I purchased a better and more reliable scooter then my previously Chinese bike.
David M.  Las Vegas, Nevada
New 2012 Kymco Agility 125cc bike
Re: Scooter batteries
« Reply #1 on: June 11, 2013, 10:20:11 PM »
How true that is. I have a battery that I add water to and its keeping the starting cracks up.
you can also add battery acid to it its only 10 bucks at meijer. I have a small deepcycle also that works great and its acid free. if ya go deepcyle it has to be big enough to crank the scoot over.
08087
  • 09' Peoples 200, NJ
« Reply #2 on: June 12, 2013, 02:20:29 AM »
Now I have to open up my batt and check the water level.
MassScoot
« Reply #3 on: June 12, 2013, 01:45:42 PM »
Buy sealed AGM batteries & the Deltran Battery Tender Jr. (12 volt) is your friend! Trust me. The best sub $25.00 you can make.
http://www.amazon.com/Battery-Tender-021-0123-Junior-Charger/dp/B000CITK8S/ref=sr_1_1?ie=UTF8&qid=1371042913&sr=8-1&keywords=battery+tender+jr
Gloucester, MA. (Home of the Perfect Storm)
2012 Silver Kymco GT300i (Biondi Windshield/Shad SH40 Cargo Topcase)
2015 White Honda PCX150 (Shad SH37 Topcase)
2013 Yellow Lance PCH125 (Shad SH33 Topcase)
axy
« Reply #4 on: June 12, 2013, 06:09:16 PM »
Kymco's OEM batteries are typically maintenance free, so I do not know how this mechanic tops them up with fluid... did he ever do a repair of Kymco scooter?
Kymco Agility 125 2008
« Reply #5 on: June 12, 2013, 09:28:15 PM »
e.
[/quote]
Hey, that's the lead that came hooked to the battery on my new LIKE 200i.
Cool......however, the best trickle charger is my rear-end in the seat with some BP 93 in the tank going down the street, rain or shine, every 8 > 12  hours.
« Reply #6 on: June 13, 2013, 01:29:04 AM »
Kymco OEM battery brands differ from place to place.  Some maintenance free batteries have caps on top, under the sticker brand. Remove sticker and pry out the plastic caps to top them with fluid.
kingkymco125
« Reply #7 on: June 13, 2013, 07:10:14 AM »
My mechanic works on all the quality scooters. He works on the Kymcos, Syms, Lance, Genuine and all major scooter brands. Him and the owner own the dealership from where I purchased my scooter.
axy
« Reply #8 on: June 13, 2013, 08:25:46 PM »
This is the best way to destroy them.
Kymco's OEM batteries do not have acid solution inside, they are dry gel batteries. The caps are there just because the casing is the same regardless of the type (acid or maintenance free) and I agree it is misleading. The best way to destroy Kymco's OEM battery (with caps) is to remove that cap and add distilled water inside.
Kymco clearly claims in the manual that the batteries are maintenance free but removable caps are clearly misleading.  (and useless, too).
ophelia
« Reply #9 on: June 13, 2013, 09:45:52 PM »
I believe my dealer gets absorbent glass mat (AGM) type sealed lead acid batteries. They come empty with a pack of acid stored separately. The cap strip is there to allow filling of the initial acid solution in the battery prior to first charge. That way, you get a fresh battery and not one that is stored activated for an unknown period of time before you get it. The strip isn't meant to be pried open after the initial fill for refilling though.
Sometimes the non-sealed lead acid batteries have a clear casing with marks on the side, so you know when to refill them.
2011 Kymco Downtown 300i
« Reply #10 on: June 14, 2013, 01:43:18 AM »
Kymco OEM batteries here are not dry gel batteries... they are supplied by a local supplier... they are labelled maintenance free but actually are acid type...
Scooters are assembled here and not completely built units from Taiwan... that's the reason they are cheaper... they are imported without the batteries....
« Last Edit: June 14, 2013, 01:47:16 AM by Vivo »
