Author Topic: reserve tank???  (Read 2759 times)
moparkid
reserve tank???
« on: June 14, 2013, 02:30:06 PM »
Does anyone know how many miles you can go once the fuel gauge starts flashing?
ophelia
Re: reserve tank???
« Reply #1 on: June 14, 2013, 04:24:41 PM »
My significant other tends to run her tank nearly to empty. She gets ~310 km (~192 mi) before she fills up. From my calculations (3.7 L/100 km, 12.5 L tank), she has another 20-28 km (12-17 mi) to go. She's fairly aggressive on the throttle too.
I don't recommend running close to empty, because you might have trouble reaching the fuel at the very bottom of the tank. Your mileage may vary too. Bring a jerry can if you want to experiment. :)
2011 Kymco Downtown 300i
moparkid
Re: reserve tank???
« Reply #2 on: June 15, 2013, 02:16:26 AM »
Agreed....I usually stop and fill the moment it starts flashing but the other day I was out in no man's land and wasnt sure where the nearest station was when it started flashing. Fortunately out of nowhere popped a small country store with a single pump...I was apprehensive about buying gas that far out from mankind so I only bought a gallon but the moment I did find a Chevron I refilled. And it is true, my bike does run better on Chevron gasoline. I would have never thought that since I had always used Shell or Mobil but my bike always seemed to sputter at takeoff since the day I had it..until I read on here about Chevron. No more sputter.
jeryll
Re: reserve tank???
« Reply #3 on: June 17, 2013, 07:28:12 AM »
Flashing about 2-2.5L to empty. My average is 25km/L (~50km-62.5km)
Yellow Fuel light "ON" 0.5L to empty.(~12.5km)
« Last Edit: June 17, 2013, 07:30:15 AM by jeryll »
Re: reserve tank???
« Reply #4 on: August 10, 2013, 08:41:48 PM »
Bumped this to share info:
Rode around until last segment started flashing which was at the 210 mile mark. Kept riding until the YELLOW  light shaped like a gas pump in the tach came on which was at the 248.5 mile mark. The last segment on the gas gauge was still flashing. Was at a non-ethanol station so filled up which took 3.22 US gallons.
I figure the DT300i is good for a solid 200 miles with a good 30 miles reserve. All this is on non-ethanol fuel. I think it will still go a solid 200 miles on 10% ethanol with a 20 mile reserve. I intend to get some Star-Tron and see what happens.
Hope this gets you closer to an answer.
Re: reserve tank???
« Reply #5 on: August 11, 2013, 01:58:16 AM »
  due to a accident did a detour and ran out of gas 100 feet from the pump , filled up 12.5   liters so it was dry to the bottom of the tank,.
Re: reserve tank???
« Reply #6 on: August 11, 2013, 07:43:55 PM »
Yeah, De-dee, the book sez the tank is 3.3 gal or 12.5 liters. Talk about finishing on fumes! OK, how many miles or kilometers was that for you from full-up to bone dry? Did you have any starting issues?
Re: reserve tank???
« Reply #7 on: August 17, 2013, 05:36:22 AM »
  If I remember it was 359 km. and it started with a 3 second start,. when it was dry I did not try to restart,  today I ran 323.3 km. and it took 11.34 liters,   and that is with some 130 kph. riding  ,. about 10 miles of that ,.
