Author Topic: S 250 coolant question  (Read 2749 times)
lrich524
« on: July 19, 2009, 12:28:58 AM »
Hi,
I just bought my 2009 People S250 this week. It is a liquid cooled engine. I looked at the reserve tank eyehole and I can't tell if there is water in there or not. I have it on the main stand but I don't see anything. How can I tell if there is water in there? How do I fill it if there is not? I've checked the driver's manual and it doesn't give great info. I don't want to ruin the engine, so any help you can give me would be appreciated.
Thanks,
Lisa
Re: S 250 coolant question
« Reply #1 on: July 19, 2009, 02:28:10 AM »
   You have to use anti-freeze in a 50/50 mix w/ water. I don't know about how to fill your scoot, but I would bet it is low if you cannot see a colored liquid through the site hole. Hopefully someone who is familiar w/ your model will post. The anti-freeze would be either green, blue, or orange. you should be able to find a fill cap for the recovery bottle.
axy
« Reply #2 on: July 19, 2009, 09:36:18 AM »
Hi,
Thanks,
Lisa
Under the steering there is plastic cap held by one screw. Take it away and you will have free access to the expansion can.
Kymco Agility 125 2008
kawzak
« Reply #3 on: July 19, 2009, 11:24:13 PM »
Hello, I also have a hard time seeing the level in the slot. Take (1) screw out of the cover above this slot/sight area, then from the front-by the fender use your hand to push out the small square panel/door as it probably is stuck (paint). after this you can get a small flashlight to easily see the level. There are marks on the coolant recovery container to go by (see them thru the slot in the fairing) ---OR-- if you wait untill night time you can just shine a good bright flash light from the front ( by the fender back towards the recovery tank) and then you can see the level thru the slot in the fairing. Hope this helps.
eemichael83
« Reply #4 on: July 26, 2009, 04:31:10 AM »
As others have said, its easier to see if you shine a flashlight at the reserve tank 'window'.  If you still cant see, take off the right side vent cover.  It has two screws and snaps in.  Once you get the two screws out, just start from the top of the vent cover and start pulling.  With it off, you'll be able to see the entire reserve tank.  To fill, I just got a clean funnel with a tube on it.  Just reach in, pull off the rubber cap, and insert the tube of a funnel.  Theres a little door on the outer plastic piece where your right knee would go that you should be able to pop off... but I got a screwdriver and tried prying it off and it didnt want to go.  I was worried about it breaking, cracking, or scratching, so I just went with the way that I mentioned.  I use the Honda 50/50 premix for my coolant.  Theres not measuring and mixing, just pour it in.
2009 KYMCO People S 250
My Playground: ScootForum.com
