Author Topic: Scooter vibration + Belt  (Read 3996 times)
Deejays50
« on: June 14, 2013, 03:49:39 PM »
Hey guys,
I finally decided to figure out why my scooter vibrates like crazy at higher speeds.
My scooter is an 08 Agility 50
I did not modify this scooter myself but it does have an aftermarket CDI, Polini Variator, and a malossi clutch.
The belt is a Kymco Bando belt.
When I had the engine running and gave it some gas I noticed the belt was vibrating up and down like a sine wave and thats when the noise started.
My question is, should I buy the stock Kymco size belt which (from research) is 729 17.7 30 ?
Or should I go with a longer belt?
Anyone have some suggestions?
Thank you much in advance.
MotoRandy123
  • Lets Ride!
Re: Scooter vibration + Belt
« Reply #1 on: June 14, 2013, 10:44:46 PM »
Thats belt slap. Some of the Vespa's have a big pulley in the middle to keep it from happening;
Not sure there's anything else you can do about it. Resonances in the system cause it so any change
could make it better or worst...
Deejays50
« Reply #2 on: June 14, 2013, 11:34:59 PM »
So a newer tighter belt would not change anything?
de-dee
« Reply #3 on: June 15, 2013, 03:58:27 AM »
have you measured your belt,. I have three belts and they are a little different size , each one of them,.  one of them is 6 mm. longer then the others,.  but I must say the more miles I put on my scooter,. the smoother it runs ,.   32,000 km. and running
Deejays50
« Reply #4 on: June 15, 2013, 04:02:48 AM »
Whats the best and proper way to measure it?
« Reply #5 on: June 15, 2013, 09:27:33 PM »
check and see how the rollers look and see if you have any flat spots. it might be time for a new clutch my 07 agilty got a new clutch after 4 years.
de-dee
« Reply #6 on: June 15, 2013, 09:38:52 PM »
  check the wifes sewing kit, look for a tailors tape,.  cross check it against a steel tape,   and measure around the outside of the belt  that will be your first #   then measure across the top of the belt thats your second # the last # is angle of belt  usually  30 degrees
« Reply #7 on: June 16, 2013, 09:09:58 PM »
X2 the degrees of the belt is what most likely wears out frist on the belts. If so its time for a new belt.
