Author Topic: How high  (Read 1111 times)
modmaster
  • I will leave no bike I own stock.
How high
« on: June 15, 2013, 04:03:55 AM »
This is a question for anyone. How high do you fill up the gas tank? I have been filling mine up just until the pump auto shutoff kicks on. How can I be sure if I'm filling it up exactly the same amount each time so I get an accurate repeat for checking gas mileage?  So far on my first 3 fillups I've gotten 79, 80, and 82 mpg which I am extremely happy with.
modmaster
Re: How high
« Reply #1 on: June 15, 2013, 05:15:03 AM »
When I fill up, it's usually around an inch from the topmost part of the tank... I only checked for gas mileage once... just out of curiousity... I'm happy because I spend less than in using my car...
Wil B.
Re: How high
« Reply #2 on: June 15, 2013, 02:42:47 PM »
After the first couple of gas-spilling fill ups, I decided to just fill fairly slowly until the pump auto shutoff.  I never try to top off.  Also I try to fill at the same station each time, I believe I'm getting consistent enough fillups to base my gas mileage calculations.  Like modmaster I'm getting pleasantly high mileage readings with almost 4,000 miles on the scoot.  The last 3 fillups have been all between 80 and 90 mpg (USA.)  That's really really good mileage for a scoot that can do so many things!
Wil B.
Broadview, IL
'71 Guzzi Ambassador
'91 Nighthawk
'04 Kymco Super 9
'10 Kymco Yager 200gt
Wil B.
2010 Kymco Yager 200
2004 Ktmco Super 9
2014 Honda CTX
"I am not a number. I'm a FREE MAN!"
Yager200i
Re: How high
« Reply #3 on: June 15, 2013, 11:10:45 PM »
Here's how I do it.
I put the bike on the main stand and turn the handlebars all the way to the right. I fill fairly quickly for the first gallon and a half, but then slow down. I hold the rubber boot of the fill nozzle away from the filler neck, so I can see when the filler neck is starting to fill up. When I have it filled to within a few inches of the top of the neck, I stop filling and rock the bike very slowly back then forward. This usually burps out a pretty significant bubble of air that gets trapped at the top of the tank proper, thereby lowering the level in the filler neck and allowing me to put in a bit more gas. I then fill it up very, very slowly to within an inch of the top of the filler neck.
Re: How high
« Reply #4 on: June 17, 2013, 01:41:55 AM »
I havent experienced filling-up my scoot or car by myself... we still have gasoline boys here...  ;D
