Author Topic: Striped Oil Plug Nut  (Read 747 times)
Miles000
« on: June 20, 2013, 08:38:03 PM »
Does anyone know what to do when the bolt to change the oil has been striped? I have no idea what to do and its driving me crazy. Thanks for any ideas :)
MotoRandy123
  • Lets Ride!
Re: Striped Oil Plug Nut
« Reply #1 on: June 20, 2013, 09:42:32 PM »
A shop can fix that for you. They might drill it out to the next size and retap it. I'd go with a
fumoto valve so you don't need to remove it over and over (you'd need the size to buy the right one).
http://www.fumotousa.com/
streido
« Reply #2 on: June 20, 2013, 10:31:37 PM »
Is it the bolt head itself to loosen it or the threads on the engine where the bolt screws into the engine block?
If its the bolt head and you cant get it off then you can try hammer on a slightly smaller sized socket onto the nut head and if your lucky it will come off that way. I did that with mine when the head got worn and the spanner kept slipping then replaced it with a new drain bolt. Dont overtighten the new one.
Chaos is my co-pilot.
Miles000
« Reply #3 on: June 20, 2013, 11:34:22 PM »
yeah its the head of the bolt.. I will try that and see if I can get it to turn.. For some reason it seemed like it was locked in place.
« Reply #4 on: June 21, 2013, 02:28:21 AM »
Go down in size on the socket. but once you get it out I would get a new thats for sure.
lefty losey righty tighty.
