Author Topic: Carb size increase?  (Read 850 times)
CaptonZap
Carb size increase?
« on: June 23, 2013, 06:14:00 PM »
I just got a Sento 50 that was stolen and trashed, and I'm trying to rehabilitate the poor thing. :-\
The carb is an eighteen mm size, and the manifold has the same size opening to the head. Can I buy a larger size carb and manifold and install them, and have any hope that it might improve performance?
I have a Shanghai Meitian 50 cc that has a 24 mm carb on it, and it seems to work well.
Thanks for any input,    CZ
Re: Carb size increase?
« Reply #1 on: June 24, 2013, 02:22:27 AM »
Yes you can a 18mm manifold will hold up to a 20 mm carb I have one on my montofino scoot gives it faster take off and the top end gets there faster. you will love it. you can even put in a bigger jet and open air filter in it and watch the looks you get from people you pass.
kymcoholic
  • Kymco Parts shipped Worldwide !
    • KymcoGenuineParts.com
« Reply #2 on: July 03, 2013, 09:08:01 PM »
If you add a larger carb you will need to open up the Airbox ( drill holes ) to let it breathe better and get full use of the larger capacity fuel charge being brought into the motor from a larger carb....but its all for not..... unless you open up the exhaust as well to let the motor breathe better, which would require a free flowing exhaust...aka new pipe....then it will rock !
