The rear brake light switch is not working, the front is so it's not the bulb. I want to get at the switch and check the contacts or replace it if needed!
Has anyone had the top plastic cover off the handle bars to expose the connection to the master cylinder? I see the 2 screws that will need to be
removed and also have to take the mirrors off. I would appreciate any helpful hints for this process...( any clips or tabs on the plastic to be careful
not to break). Thanks to all for such a great forum!
