Hey Guys,
I got a super fever a year ago for free from my girlfriends manager. He said something was wrong with it when he was riding and when he took it into the shop they said it would cost $400 to replace. I think he said it was the stator but I could be totally wrong. Not sure on the year but it only has 5000 k/m on it (I live in Wisconsin so that would be 3,100 miles roughly).
Here's the story. I pick it up and take it over to my buddies house and the battery is dead. But we were able to get it running kick starting it. Only problem was when operating and then goosing the throttle it would bog a little, so back off the throttle then if turned slowly would accelerate to top speed just fine. We figured the carb just needed cleaning. Waited all winter to start working on bike. I cleaned out the carb, put it back on, kick started it again and it fired right up (once finally got some fuel into carb). I drove it around for about 20 minutes putting it through it's passes and again topping out at 40 mph. Had to go back to my garage to do a couple of things but left it idling for about 3 minutes and decided to go back out. Took one corner around my house and had to stop for traffic, then the engine died. I kick started it again and it fired right up but was no throttle response and died again. Started it one more time and had to have full throttle to keep it running then died again. I push back to my house to investigate. I put new oil and new gas (not sure how long old gas was in it and used premium.) Checked for spark and had good spark.
Here is what I have done since then. Bought a new battery because was tired of kicking it to start and also, if could get it to run then would know would have to replace stator. Cleaned out the carb yet again. Checked the fuel flow and have good flow. I can't even get the thing started by using starting fluid. Now I am at a loss. If anyone has any input as to where I could progress from here that would be greatly appreciated. Sorry for the long novel but figured the more info you guys have the better!
Jon
