Author Topic: Starter Solenoid Experiences?  (Read 4249 times)
Urbestfriend
« on: July 20, 2009, 05:13:02 PM »
Reference earlier post by Urbestfriend regarding "Starter Dragging".  My next step was to check the started solenoid.
One thing I noticed was that engine started fine once it was warm.  Basically starter was only 10-15% effective when
engine was cold.   I have pulled the covers off and it's interesting that when I heated the solenoid with a heat
gun,  it went from just weakly spinning the starter motor by itself to actually trying to engage the bendix.  I will
be trying some of the voltage checks from the manual,  but I don't think they'll give me the information I really need.
So....The question is:  Has anyone had a bad Starter Solenoid on an Agility 50 before?
Re: Starter Solenoid Experiences?
« Reply #1 on: August 10, 2009, 01:37:38 PM »
..I'm going through the same thing right now...it just started day before yesterday...
..I thouhgt my battery was dead, so I put in on a charge...Battery is OK...
..Once my engine heats up, the starter will fire the engine..but will not from a "cold" start...
..one kick and I'm up and running...
..I'll be monitoring this thread for some ideas...lol...
« Reply #2 on: August 19, 2009, 04:51:28 AM »
Heat in electronics increases conductivity allowing more amperage through any given circut Just replace both parts. You wont have to walk!
Hiriser
« Reply #3 on: August 19, 2009, 05:00:19 PM »
Had a similar problem on my Roketa 50cc where it would only catch 10-15% of the time.  Replaced the solenoid and it works like a champ.  Odd thing I found is the Chinese/Taiwanese Service and Repair Manual I have doesn't point to it as being a problem or symptom of the starter not spinning or only periodically spinning.  Go figure.
Urbestfriend
« Reply #4 on: August 19, 2009, 07:47:07 PM »
Now here you go...Urbestfriend received the solenoid,  installed it and put everything back together.
Same thing happened.  Charged the battery numerous times but the voltage always registered 12.0+
before and 13+ after.
Took the battery (Came with new bike new 15 months ago) to Interstate.   They said the battery
had no holding capacity.   Who would have guessed a new battery would go bad in such a short time ?
Again...Battery would charge to 13+ VDC and slowly,  but surely dip to 12+.  Hope I explained this
correctly.  I didn't respond because there were no replies until now.
Remember...You might say.."Why this bike has a 2 year warranty."   That's fine,  but the dealer is
an hour away,  so it would have cost as much for gas (2 round trips).  Just easier to fix it myself.
« Reply #5 on: August 19, 2009, 08:21:28 PM »
...well, then...that might also explain why my headlamp goes dim now, when I apply my brake...
..my scooter is 18 months from new...
..U R mybestfriend....
peace
