Author Topic: zx keeps bogging down after full speed  (Read 1415 times)
SUNDECKA
  • Madden Junkie
« on: June 26, 2013, 12:28:26 AM »
engine stays running,but will stall if i try and twist it.?
motor is strong only 1700 miles..
brand new belt,auto choke,gear oil,piston and i've tried three different variators and two clutch asseys
after sitting briefly, the bike will start back up and ride fine.
i'm at a loss guys i need some help please
"ONE LESS CAR"
2012 super 8 2t
200? ZX 50 super flu
2010 sunny 50 4t...10.000+miles
naughty lee
  • 64 mph and pushing
Re: zx keeps bogging down after full speed
« Reply #1 on: June 26, 2013, 06:15:57 AM »
Have you set up your air mixture? If you remove your spark plug, what colour is the insulator around the igniter ?
SUNDECKA
  • Madden Junkie
« Reply #2 on: July 01, 2013, 06:09:29 PM »
wow.i was almost sure i had a new plug in there :o....
new spark plug no bogging down at all.
36mm boss with 8 gram rollers,yellow contra spring
she cruises at 48/uphill 35-40/downhill 55-60
all stock.not sure of the mpg yet
"ONE LESS CAR"
2012 super 8 2t
LoveMyKymco
« Reply #3 on: July 02, 2013, 01:05:31 AM »
Sounds like you got her all straightened out, the plug will def do it to you. I have a few KE100s that foul the plug after a couple rides every time, and man let me tell you itll make you think your carb is out of whack. Glad to see its good now!
SUNDECKA
  • Madden Junkie
« Reply #4 on: July 03, 2013, 01:49:43 PM »
yes no more zx stress..
now onto the super 8 i kinda blew up.lol
new crankshaft/bearings/seals and a nice lill malossi kit should change her attitude
"ONE LESS CAR"
2012 super 8 2t
LoveMyKymco
« Reply #5 on: July 03, 2013, 01:55:30 PM »
Make sure to open the boost port from the crank to the cylinder while you have it apart, also open up the intake tract a lot.
