Author Topic: Turn signal Problems  (Read 1456 times)
Hocky
« on: June 26, 2013, 08:52:20 PM »
I have a 2006 GV that runs great!  Lately however, the turn signals have started to fail.  First it was maybe 10% of the time; now they are completely gone.  Everything else on the scooter works just fine.  Is there wiring in the switch that can be tightened?  In looking for a solution I find that there in no fuse labeled for the signals.  Is there a fuse located elsewhere?  Thanks!
MaryK
Re: Turn signal Problems
« Reply #1 on: June 26, 2013, 10:50:32 PM »
Not a problem on my 2009.
All of the fuses are in the box by the battery as far as I know.
If both left and right quit at the same time, I'd replace the relay.
No, I don't know where it is located.
They call it the winker relay.
It uses Fuse B (15A) for winker, Stop, Horn, Meter, and more
So, I doubt the fuse is bad.
scoot safely,
« Last Edit: June 27, 2013, 11:43:10 AM by MaryK »
New Rider in 2010
2009 GrandVista 250
windwheeler
    • WindStrom windshields
« Reply #2 on: June 27, 2013, 02:57:28 AM »
Sounds like your turn signal relay could be giving out.  I don't know where it is located, but I would first check there if the contact for power and ground is steady coming to it, if so, replace the relay.
Urbestfriend
« Reply #3 on: June 27, 2013, 05:17:54 PM »
I believe you have to pull off the front cowl.  Check the Parts List on the Internet.
Look under winkers or Electrical on the listing and it'll give a general idea.
windwheeler
« Reply #4 on: July 02, 2013, 02:22:01 AM »
Please let us know what the problem was.
