Did you miss your
activation email
Scooters - 125 to 300
People 250
Wire Couplers
Topic: Wire Couplers (Read 1259 times)
kymcoallan
Jr. Member
Wire Couplers
June 27, 2013, 09:10:11 AM »
Perhaps a small problem, but it's hard to explain. When I shall have
box up on the seat in so I can get down to mortoren, seat box then there are 2
wires to be the first. One is the light down in the seat box and the other is to
a charger for mobile phone. The one with the light it's easy enough to get separated, but the
Mobile phone lets it I do not see how is assembled and can not take it apart
even if I pull at each end. How is it collected? how separated the ad? each
time I had to turn it apart and it is quite difficult especially when it is now clear
probably it is to disassemble. But how? has some experience and can help?
Elderly man, fond of his MC Scooter
Punk052
Jr. Member
Re: Wire Couplers
July 26, 2013, 08:31:17 PM »
Mine has a simple clip that you have to pry up while seperating the wires. It might be tied to the frame farther down the wire
ispud
Sr. Member
Re: Wire Couplers
September 02, 2013, 02:49:36 PM »
That plug is a pita!! I always have trouble with it. It is very simple once you figure out where to lift up tab. I always have to get one of the guys in my shop to do it.
California kid
Newbie
I'm here for the Chicks!
Re: Wire Couplers
Reply #3 on:
October 11, 2013, 06:52:33 PM »
I just did this the other night.
Disconnect the battery.
Then disconnect the lamp by pulling the lamp housing out 1st, the uncoupling the disconnect. Then I pulled the plastic tub out from the under seat but still had the charger plug connectedso the tub was only partially up. I got access to the disconnect for the charger plug at the rear of the space. Easy Peasy from there on.
Ck
People 250 NO 'S'
Lammys and Chetaks
TLRam1
Sr. Member
Re: Wire Couplers
Reply #4 on:
October 12, 2013, 03:25:49 AM »
What is under the seat box you need to access?
Terry
10 Kymco People S 250
87 Yamaha Riva 200 (Sold)
Allen TX (Dallas)
cli-maxridinggear.com
de-dee
Sr. Member
Re: Wire Couplers
Reply #5 on:
October 12, 2013, 05:17:52 AM »
when you do a service check up,. ckecking Battery, fuses, if one has blown, and easy to clean a little, and the spark plug,.
Back
