Author Topic: Chromed Round Cover on Right Side of Motor  (Read 1661 times)
doublej
« on: July 01, 2013, 10:54:18 AM »
Does anyone know what it is for and what is behind it.  Reason being I am seeing flaking chrome  on it and thought of replacing.  anything I need to be aware of when I remove the three 8mm machine screws.  thanks
ophelia
Re: Chromed Round Cover on Right Side of Motor
« Reply #1 on: July 01, 2013, 02:33:04 PM »
It hides the crankshaft nut that you can use to manually turn the engine to set timing and valve clearance. A little oil may weep out when you are opening that cover, but don't be alarmed.
2011 Kymco Downtown 300i
doublej
« Reply #2 on: July 01, 2013, 08:23:47 PM »
I thank you for the quick reply as to its use. Very helpful.
