Author Topic: Another de-restricting thread.  (Read 2924 times)
Bob Ryder
« on: July 02, 2013, 05:51:22 AM »
Hello all I'm new to the forum, and kymco scooters in general.  I purchased a super 8 2t 2012 in the south east USA.  I'm currently trying to de-restrict my ride.  I've read tons on this subject but haven't found much help.
My drive boss isn't restricted, the cdi doesn't have the pink or purple wires/but yet there seems to be some kind of electronic restriction limiting rev/, I"m planning on removing the blind pipe on the exhaust to get pass that issue.
So what I'm wondering is there any one who can point me in the right direction on where to find the restrictions?  What am I over looking.
naughty lee
  • 64 mph and pushing
Re: Another de-restricting thread.
« Reply #1 on: July 02, 2013, 06:08:48 AM »
There maybe a restrictive washer in the top of the exhaust, how fast is the scooter at the moment ?
« Reply #2 on: July 02, 2013, 06:09:29 AM »
Welcome Bob Ryder...  :)
What is your current speed?
Bob Ryder
« Reply #3 on: July 02, 2013, 06:08:16 PM »
currently it does about 35 to 37 if there is enough flat road.  On hills only goes about 20 to 25.
AS for the exhaust there is no washer, but it does have the blind pipe, and the egr connection.
I plan removing the the blind pipe this weekend.
naughty lee
« Reply #4 on: July 03, 2013, 06:45:21 AM »
Ink your inner variator with a sharpie, then take it for a run to top speed. Does the drive belt rub all the ink off? Or is there ink left towards the outer edge of the variator ? If so, how much?
Bob Ryder
« Reply #5 on: July 03, 2013, 07:45:31 AM »
Belt appears to have full travel to the top.
« Reply #6 on: July 03, 2013, 08:12:05 AM »
pump up your tire pressure to the max and try again...
drewfish
« Reply #7 on: July 03, 2013, 12:52:51 PM »
Weld up the small pipes on exhaust I did this and couldn't believe the difference.then change jet to about an 88. I'm not a big fan of the carby on my 2012 super8 even with the bigger main jet so I've ordered another carb from e-bay that will bolt straight on, ill put up a new post if its a good improvement
Go hard or die trying,lol
naughty lee
« Reply #8 on: July 03, 2013, 02:31:01 PM »
Did you mark it with ink ?
Bob Ryder
« Reply #9 on: July 05, 2013, 05:58:39 AM »
Yea I used a sharpie, the belt runs to the top.
Today I did the exhaust mods, and now it gets up to 40+ but not 45.  Holds the hills much better around 30 to 35 depending on the length and pitch of the hill.
But now I'm wondering what's the rpm range of this engine?  Currently I'm getting 7200 rpm topped out riding and on center stand.
Alss what's the best approach increasing hole shot?  Takes my bike almost a mile to top out.
bgblock
« Reply #10 on: July 09, 2013, 10:50:04 AM »
Hi bob im new here also . I am working at kymco dealer northern maine and i am purchasing  2013 super 8 2 t .
Have you got yours going better. dont see much action here is there another forum with info on it .
I need mine to pull huge hills  so i need more out of it and trying to save time ...
thanks  dom
naughty lee
« Reply #11 on: July 09, 2013, 11:25:34 AM »
Bob, you can try lightening the variator rollers, this may give you better acceleration ( but if you lighten too much it will be at the expense of top end speed)
I've put a thread up in the zx50 area that has info on carb mixture settings, you may be able to lean your mixture out a little and gain a few revs ( and more mph ) if the belt is taking all the ink from the variator, then your boss length is correct, an upgraded variator is the next logical upgrade.
For price though, try altering your mixture, be sure to fit a new spark plug though so that you can check its colour after a couple of days to make sure it's not leaned out too much
Bob Ryder
« Reply #12 on: July 10, 2013, 04:13:56 PM »
Hi bgblock at this point I'm stuck.  Can't seem to find the rpm hold back on this bike.  The exhaust mod, or just buy a nice tuned pipe will help greatly, then of course retuning the carb.  But even with that I'm still stuck at 7300 rpm.  This motor should do 9000 to 12000 from my understanding.  So I'm still looking to correct that.
As far as the weights go.  I've tried lighter ones, about a gram and a half lighter, and it took even longer to come up to speed.  This could be due to me being a light weight at 145 lbs.  Still waiting on a heavier set to arrive to test the other direction.
If anyone has any ideas on what is holding back the rpms please let me know.
