Author Topic: Anyone tach an iridium plug vs stock NGK?  (Read 1096 times)
« on: July 08, 2013, 09:25:35 PM »
Buying a small tachometer to run some tests on my LIKE.
Going to check the idle speed with an Iridium plug and with the stock NGK plug - .
Also will check RPMs at some steady speeds before and after installing Dr Pulley slider weights.
Will probably keep it in my front glove box, pull it out & set it on the dash with some velcro when I want to explore things.
Digital is fine for my purposes. (Trail Tech)
91cavgt
Re: Anyone tach an iridium plug vs stock NGK?
« Reply #1 on: July 08, 2013, 10:46:08 PM »
I installed an NGK Irridium plug and found no change in engine rpm or how the scooter responded.  My scoot had 1300 miles on the stock plug.
2012 Like 200i  in black
