I recently had a similar problem. I replaced the fuel filter, dis-assembled my carb, cleaned with a spray contact cleaner..every port...Never saw any trash, but when I re-assembled everything, all was fine.
..I went riding this past sunday, all over the county, and encountered a cpl of gravel roads. All was fine until I parked overnight...The next morning I fired my scoot up...let it warm up a bit and shut it off. Went back out 5 minutes later and she would not run...Pumping the throttle would push a little fuel from the accellerator pump, but after that it would not run...So, I dis-assemble the carb, and wow....
...Very dirty....
..Upon further inspection, I found a small slit in my air filter...
