Author Topic: Bad gas mileage on a 2010 Super 8  (Read 1269 times)
azad814
« on: July 11, 2013, 03:10:59 AM »
I just got it back from the shop after the battery died on my 2010 with 800ish miles on it.
I filled it up at 825 and now I am at about 838 and I am sitting on just over half a tank.
Am I really getting this bad of a gas mileage or is my guage broken or what? Ideas anyone?
I have to go back to the shop since the kickstarter broke when I tried to start it after the battery died. :(
Re: Bad gas mileage on a 2010 Super 8
« Reply #1 on: July 11, 2013, 05:17:12 AM »
My scoot had bad mileage when new and improved after lots of miles riding... now, the odo reads 16,000+  mileage got better...engine runs smoother....
Some tuning and better oil plus lots of riding will improve mileage...
« Reply #2 on: July 11, 2013, 10:37:07 PM »
You need fill it up, ride it a reasonable distance, 50 miles or so, then fill it up again.  Then calculate gas mileage.  Do this a few times and average the results.  The gas gauge may be way off.
I normally get 70-75 MPG and run 45+MPH most of the time.  I've gotten over 80.  If your getting much less than that, something is wrong
azad814
« Reply #3 on: July 23, 2013, 10:21:14 PM »
I have filled her up 3 times now, each time with just about a gallon and I have been getting about 50 miles a gallon I guess since I fill it up right when it hits the red zone on the fuel gauge. The dealer is ordering a new fuel sender or some part under warranty to see if it does anything. Also, yesterday while riding I noticed that my headlight would not brighten when pulling the throttle, but instead shut off completely. I know they are supposed to dim, but not turn OFF when riding. I parked it, restarted the bike and it was back to normal... That kinda freaked me out.
skishades
  • Point 'em and Pray
« Reply #4 on: July 31, 2013, 04:30:50 AM »
The CDI sends a signal to the Light Control Module that controls the lights.  Either the signal got lost or the LCM malfunctioned. If you bypass the LCM, you can blow a fuse since the hi/low function of the light share a ground which means it can power the light your not trying to use after it has passed through the lights.  I wouldn't worry about it unless the problem persists.
I will ski till Hell freezes over... then I will have no fear of death.
