hey
i see others grinding the boss down to get more top end. i have questions about that
first does grinding the boss mean i get taller gears all the time, so should put in lighter weights so i don't lose bottom end
second so i don't mess up my boss if i grind too much or dont get it straight, wht if i used my old restricted boss with the shoulder on it, and ground off the shoulder. and how smooth does the shoulder have to be, when ground down, is it like a machined surface, if its not perfect will it still be ok?
thanks
