It could void the warranty since it won't just plug in. You also have a very small engine with a CDI that dims the lights just to safely start the engine. If you start adding lights, it could cause fuses to blow. If your lights cause a fire, it definitely won't be covered under warranty. Basically, just know that if you change any wires, Kymco won't be responsible for that part anymore... and might not be responsible for parts affected by that part. I blew a fuse on mine while adding the top case and it blew out the computer on my alarm, then blew a fuse... I was lucky it wasn't the CDI. Since you have such limited power available, I wouldn't add lights unless you are saving power somewhere else (such as an LED change out).
