Author Topic: Carb location  (Read 3175 times)
luc1992
Carb location
« on: July 26, 2009, 04:02:32 PM »
Ok, call me stupid but i wanted to lean out the carb a bit today because after taking my spark plug out i noticed that it was blackish and had carbon deposits on it. Anyhow i looked on both sides of the scooter for the mixture screw (i figured it would be relatively easy to access because it needs to be tinkered with every once and a while) and i did not find it. So i moved to the next obvious location and i took my seat off and looked down. Now i have found the carb because the throttle cable comes to an end and operates carb so i know i can see that carb. But i cannot find the adjustment screws??
I went on google and checked some various carb diagrams to find the usual place for the needles and after further inspection i could not find them!?.
So if some nice fellow wouldn't mind giving me further info on the location of these adjustment needles i would be grateful.
Some pictures would be greatly appreciated as well. As long as i find the needles it does not matter lol.
Thank you.
axy
Re: Carb location
« Reply #1 on: July 26, 2009, 05:02:46 PM »
Thank you.
Which scooter?
Kymco Agility 125 2008
luc1992
Re: Carb location
« Reply #2 on: July 27, 2009, 12:22:12 AM »
Oh the kymco people 50 (2 stroke) sorry
axy
Re: Carb location
« Reply #3 on: July 27, 2009, 10:17:58 AM »
Go to http://www.stadiumyamaha.com/pages/parts/viewbybrand/73/Kymco.aspx , select Kymco, Agility, 50.
Take a look at exploding diagram.
I would say, somewhere underneath...
luc1992
Re: Carb location
« Reply #4 on: July 27, 2009, 03:21:45 PM »
awesome, thanks. I will report later when i find it.
luc1992
Re: Carb location
« Reply #5 on: July 30, 2009, 08:04:00 AM »
ok so i found the screws on my carb and here is my next problem. there are two that are ajustable, a small one that sticks out and a larger one that is flush with the carb. I have not played with them yet because first i would like someone to tell me which is which and also the default factory settings for these two screws. also once i re-adjust them to factory setting, i would like to lean out the mixture just a bit because my spark plug is not brown but rather black.
Thanks a million to whoever will help me.
Shaka
Re: Carb location
« Reply #6 on: September 28, 2009, 11:05:30 PM »
Maybe a little late, but the smaller of the 2 should be the mix and the larger the idle.  I'm not sure of the factory settings, but just screw them in all the way and keep track of exactly how many turns on each so you can always revert back.  Usually 2 turns out on each is a pretty good starting point.
luc1992
Re: Carb location
« Reply #7 on: October 01, 2009, 03:55:29 AM »
I had figured it out and tuned it pretty darn good, but i will definitely keep this post for future reference, thanks!
