Author Topic: changing transmission fluid  (Read 8537 times)
wildwood
« on: July 21, 2013, 08:39:27 PM »
Hello, all -- I've been riding motorcycles and scooters for several years; I've even owned two Kymcos before my new 2009 XC250.
The bike I bought was a dealer demo/auction purchase -- it had 250 miles on it.  I've put another 250 on, and since I'm nearing the 600 mile service mark, I want to do the oil change/transmission fluid change in my garage.
Oil change is no problem, but I'm trying to figure out the service manual instructions for changing the tranny fluid -- it says to remove the bolt, drain the fluid (turning the wheel) --- and then to replace the bolt and new washer (?) and THEN refill with fresh SAE90 fluid.  Is there another place to add the fluid, or am I supposed to use the exposed bolt-hole before replacing the bolt.
Thanks for your help.
de-dee
Re: changing transmission fluid
« Reply #1 on: July 21, 2013, 10:55:31 PM »
you should have a bolt at the rear of tranny for filling,. and only put the right amount in, or it will end up in your air filter ,   it happend to me with my 300i downtown,.
CosmoKorny
« Reply #2 on: July 21, 2013, 11:15:09 PM »
One for draining, one for filling.  .18 liter.
Normal is boring.
2006 Kymco Xciting 250
CosmoKorny
« Reply #3 on: July 21, 2013, 11:18:02 PM »
And welcome, it's great to have another xc250 owner on board!
Normal is boring.
wildwood
« Reply #4 on: July 22, 2013, 01:10:42 PM »
Thanks - I appreciate the pictures, as well.  When I changed the oil, I used a simple measuring cup from the local Wally World -- it had the mL markings, making it easy to measure .9 L of motor oil.  How did you measure .18 L of transmission fluid?  Did you must eyeball the .2 mark?  Also, it appears one needs a special tube or super-skinny funnel to fill at that bolt location....? ???
MaryK
« Reply #5 on: July 22, 2013, 01:39:01 PM »
Many get a Vet. syringe or turkey baster to add oil to the rear gearbox.
The syringe has cc (mL) measurements on it and a big needle or tubing makes the job easy.
Some use a ketchup dispenser.
Maybe these conversions will help
180 mL = 6 oz.
0.9 L = 30 oz ,which is close enough to 1 qt.
There is a plastic tapered measurement cup, used for making oil:gas dilutions for 2-cycle engines.
It is pretty good for the smaller measurements.
scoot safely,
New Rider in 2010
2009 GrandVista 250
wildwood
« Reply #6 on: July 22, 2013, 07:33:50 PM »
Thanks for the help.   Any ideas on reinstalling the bolts with "new sealing washers?"  Are these washers available at the local Home Depot?
MaryK
« Reply #7 on: July 22, 2013, 08:34:25 PM »
If you do not over-tighten them, the washers are good for about 3 uses.  Try to keep the same side towards the bolt.
Measure or take it to an auto parts store for replacement.... about $2 for 2 or 3.
Be sure to get the same composition.  Plastic & rubber ones tend to vibrate loose.
Scoot safely,
New Rider in 2010
2009 GrandVista 250
CosmoKorny
« Reply #8 on: July 23, 2013, 03:23:34 AM »
All these years, changing oil and doing it wrong every time... and I have yet to replace a drain plug washer.  I wonder how many oil changes my Honda Odyssey with 301,000 miles has been through.  Of course now that I've jinxed myself I'd better schedule a trip to the auto parts store.   :)
Normal is boring.
MaryK
« Reply #9 on: July 23, 2013, 05:33:16 PM »
The metal for an automobile oil pan tends to be stronger (and heavier) than the scooter/motorcycle counterpart,
so it is best to err on the safe side, especially when giving advice.
 If I said "Reuse the seal and just keep tightening it until it doesn't leak",
 I wouldn't go to scooter heaven. :'(
scoot safely,
« Last Edit: July 23, 2013, 10:21:47 PM by MaryK »
New Rider in 2010
2009 GrandVista 250
CosmoKorny
« Reply #10 on: July 23, 2013, 06:00:53 PM »
 If I said "Reuse the seal and just keep tightening it until it doesn't leak",  I wouldn't go to scooter heaven.
scoot safely,
I stand corrected.   :)
Normal is boring.
wildwood
« Reply #11 on: July 24, 2013, 01:07:24 PM »
Well, I did it -- and I gotta say, changing the tranny fluid is a huge p.i.t.a.  I'm going to look into the vet syringe method and see if that works better.  Thanks again for the help; I'm sure I'll be back with more questions soon.   ;D
CosmoKorny
« Reply #12 on: July 24, 2013, 01:14:58 PM »
Glad you were successful.   :)  But a huge pita, really?  Taking it to a dealer, dropping it off, getting a ride to work, waiting for the service to be completed, getting a ride back to the dealer, now THAT is a pita.
Normal is boring.
wildwood
« Reply #13 on: July 24, 2013, 01:53:58 PM »
Good point, Cosmo -- I am a do-it-yourselfer at heart; I always prefer to wrench on my toys in my own garage, if at all possible.  The p.i.t.a. is getting the oil into that tiny opening -- a lot of trial and error, using an oil squeeze bottle.  My initial expectation was that it would be as easy as changing the engine oil...but you live and learn.
CosmoKorny
« Reply #14 on: July 24, 2013, 02:10:47 PM »
OK, well here's what I did.  Marked "full" on oil bottle, poured .18 liters into a cheap measuring cup, marked new oil level on bottle, poured oil back into bottle, squeezed oil into fill hole until oil reached new mark.  Now you know for next time.  :)
Oh, and I see I put decimal point in the wrong place when I wrote on the bottle.   ::)
Normal is boring.
