Author Topic: changing transmission fluid  (Read 8528 times)
wildwood
Re: changing transmission fluid
« Reply #15 on: August 15, 2013, 07:04:39 PM »
I found a grocery store-bought "meat injector" used to inject marinades into pork and turkey -- it has measurements in mL on the side and fits perfectly into the fill hole.
« Reply #16 on: August 16, 2013, 01:57:33 AM »
[/quote]
Don't let Vivo see this scooter. He'll give you the dickens for a dirty scooter!
R19Roum
  • R19RoumRU
« Reply #17 on: December 11, 2014, 11:40:07 PM »
My transmission was rebuilt many years ago and about 5 years ago I had the car to Bakers Auto and I had them do a transmission fluid change.  Since I have not had to top off the fluid in many yearsI have forgot which ATF to use.  I am not sure if I should be putting in Ford Type F or Mercron/Dexron.  I think I should use Type F.  Which is the correct fluid for my 67 Lincoln?
« Reply #18 on: December 12, 2014, 12:59:21 AM »
Is info on the fill cap?
« Reply #19 on: December 12, 2014, 04:41:36 AM »
Here is the owners manual. Modern Dextron III will replace the old type "F" fluid.
http://www.lincolnlandinc.com/browseProducts/browse.php/PData/category~708
