Author Topic: gas smell  (Read 2614 times)
mverps
gas smell
« on: July 29, 2013, 06:26:31 PM »
does anyone have any ideas why when I stop I smell gas really bad, I don't see any obvious leaks anywhere. My mileage is bad about 45 mpg. My idle is a little high, but that shouldn't dump gas somewhere. /any ideas would be appreciated.
Thanks, Mike  :(
windwheeler
    • WindStrom windshields
Re: gas smell
« Reply #1 on: July 29, 2013, 06:54:13 PM »
You could have very small leak from the fuel pump to the carburetor.  As soon as you stop the engine you would not be able to see anything, but it constant leaks while driving.
Also, removing the whole seat assembly (2 floor screws, 4 seat bolts) will expose anything that would leak under there if you run the engine.
I think what you describe you'll have a leak on the "positive pressure" side.
mverps
Re: gas smell
« Reply #2 on: July 29, 2013, 07:10:14 PM »
Thanks Windwheeler, I will pull the seat assembly off and see what I can find.
Mike
MaryK
Re: gas smell
« Reply #3 on: July 29, 2013, 10:39:35 PM »
Or the float bowl may be overflowing due to a leaky float needle valve.
So, while looking for a hose leak, also look at the floatbowl and the drain tube at the bottom of it.
scoot safely,
New Rider in 2010
2009 GrandVista 250
mverps
Re: gas smell
« Reply #4 on: July 31, 2013, 04:41:37 AM »
Weird, but here is what I did. Pulled seat assembly, checked all lines and carb, no gas leak anywhere. I readjusted the Idle back down to where it is supposed to be, put everything back together and ran it around the block, turned off and no gas smell. Went for a 70 mile ride today with several stops where it was shut off and no gas smell. So what does the idle have to do with this mystery?
« Last Edit: July 31, 2013, 04:53:12 AM by mverps »
Re: gas smell
« Reply #5 on: July 31, 2013, 05:27:37 AM »
Maybe you filled the fuel up to the brim and it overflowed to the vapor canister... you can smell gas with that...The fuel vapor canister, also known as a charcoal canister because it is filled with charcoal, is part of a vehicle's pollution control system and is used to capture fuel vapors emanating from both the fuel tank and the carburetor. Filling up may cause gasoline to reach the hose/tube going to the canister...
« Last Edit: July 31, 2013, 05:32:21 AM by Vivo »
windwheeler
Re: gas smell
« Reply #6 on: July 31, 2013, 05:40:02 AM »
HOW did you turn the idle down, via (1) mechanical butterfly adjustment screw, or (2) idle/pilot mixture screw?
If (1) no rational explanation, coincidence, probably "will come back", if (2)a possible explanation
However, smells here or not, what counts at the end how your gas mileage shows clearly that everything is OK.  If its mpg fell into the 40's and even the lower 50's mpg it does indicate a poor running Kymco G/V engine.
PS: MaryK: I like your idea of the stuck float bowl; I had that on one motorcycle and had similar symptoms like "mverps" G/V.  However, at one point it poured out gas when driving, so it was VERY obvious what happened.  Sometimes fuel additives can help to get rid of impurities in the carburetor, or better soltion, taking the float bowl off, or draining it if it has a large bottom nut, and cleaning out any possible impurities.
mverps
Re: gas smell
« Reply #7 on: July 31, 2013, 07:57:57 PM »
windwheeler, #1.  Vivo, I may have overfilled it, how close to the top should I fill it to? When I filled it yesterday,  I quit when the nozzle shut off. Time before I squeezed some extra into it.
Re: gas smell
« Reply #8 on: August 01, 2013, 01:28:01 AM »
Not familiar with the GV tank....
windwheeler
Re: gas smell
« Reply #9 on: August 01, 2013, 06:10:22 AM »
I fill my G/V always full to the very top to get proper gas mileage readings and never had a problem;  on two different G/V's. I don't think that's your problem.
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
Re: gas smell
« Reply #10 on: August 14, 2013, 06:15:13 AM »
When I fill to the top (almost always) sometimes I get a gas smell but it goes away after a few miles.  Not supposed to fill to the top but I'm afraid of running out when I go beyond 110 miles.
PaulC
windwheeler
Re: gas smell
« Reply #11 on: August 14, 2013, 01:27:54 PM »
With 55 mpg what you get you can go safely 115 miles; you WILL run out of gas at about 128 miles.
mrbios
Re: gas smell
« Reply #12 on: August 22, 2013, 07:32:37 PM »
Once I got to 119 mpg and I was afraid of running out.  It is good to know 110 to 115 is a safe max.  Thanks.
PaulC
