Author Topic: Stripped Drain Plug help  (Read 1381 times)
Hotcakes
  • Man of many talents
  • Kevin
« on: July 30, 2013, 07:53:53 AM »
after trying to drain my oil for an oil change the plug is stripped
any ideas on how to get this out.. per say vice grips
so annoyed
also if anyone has a link to a replacement drain plug/bolt would be great
Emt, Bartender, Podcaster
ophelia
Re: Stripped Drain Plug help
« Reply #1 on: July 31, 2013, 06:10:20 AM »
Did you strip and destroy the threads on the pan, or did you round off the head of the drain plug bolt?
2011 Kymco Downtown 300i
kymjongilco
« Reply #2 on: July 31, 2013, 09:06:45 AM »
HI , it's easy done the nut is very soft
here is a link for just the sump plug and oil seal
http://www.exportstrength.com/product_info.php?products_id=300
and here is a link for the same plus the spring and oil strainer
all Free world wide delivery
http://www.exportstrength.com/product_info.php?products_id=301
Hope that helps
When that happened to mine i used a combination of Punch and hammer near the edges to start it moving a little)  and then mole grips
Good luck !
Hotcakes
  • Kevin
« Reply #3 on: July 31, 2013, 07:32:16 PM »
rounded the heads off the bolt.. it was in super tight and I did not have a 17mm socket
so I kinda did it too myself.. gonna order a replacement one
thanks guys
ophelia
« Reply #4 on: August 01, 2013, 06:26:01 AM »
Are you unable to turn it now with a proper 17 mm socket and a 3/8" drive ratcheting wrench?
Hotcakes
  • Kevin
« Reply #5 on: August 06, 2013, 05:40:35 AM »
went to my mechanic friend, we were able to get it off and back on
I did order another bolt from my dealer
will not have to worry about this till fall or possibly spring
