Author Topic: Where's the Oil Screen?  (Read 1860 times)
fonejack54
« on: July 30, 2013, 03:01:23 PM »
  Just to clarify; I know the oil drain is on the left side of the Agility 125 when sitting on it. Is the large nut on the right side under the engine where the oil screen is? Also, where can I buy a repair manual ?
  Another question. Can I remove the oil screen and clean it without all the oil coming out?
« Last Edit: July 30, 2013, 04:57:39 PM by fonejack54 »
kymjongilco
Re: Where's the Oil Screen?
« Reply #1 on: July 31, 2013, 08:54:12 AM »
Hi , it's up under the large nut on the bottom of the motor , it's a conical wire screen , you might as well change the oil at the same time as it will pour out once the nut is removed , It doesn't use must oil in the sump so a 1 liter bottle of 10/40 (mobil i use ) will be more that enough ,
More neglected is the EP 80 / 90 gearbox oil in the small reduction  gearbox in the very end of the transmission , near the rear brake adjuster , i would always change that too as sometimes it is NEVER done from new  , you only need a 100 ml tube of this , all Kymco scooters have this and most are neglected , there are many bearings and expensive gears in there , it's a sound investment to do this ,
Hope that helps
terminalbeard
« Reply #2 on: August 13, 2013, 10:52:57 PM »
My Agility 125 took 200ml or cc of gear oil. Owners manual says  .02L of oil .02L = 200ml
2013 Agility 125 Blue
vachira
« Reply #3 on: November 20, 2013, 08:28:36 AM »
Kymco Agility 125 RS Yellow
Vision
« Reply #4 on: November 22, 2013, 01:58:11 AM »
Hi
This might help. :)
http://kymcoagility125.blogspot.com/2013/11/how-to-change-your-gear-oil-or.html
Cool blog. Is that yours? It's needed.
We need a tutorial on an oil change.
vachira
« Reply #5 on: November 23, 2013, 03:32:17 AM »
Hi Vision,
Yes it's my blog. :)
I decided to make one, because all the other Agility blog either on Spanish or Portuguese.  :o
I owned a Yellow Kymco Agility 125, I think in another country they called it Agility 125 RS.  ;)
vachira
« Reply #6 on: December 17, 2013, 03:38:43 AM »
Hi Vision,
Hi,
I change my blog to wordpress because Im having an issue with the old site.
Here is the new site http://vachiraphuaklek.wordpress.com/2013/12/11/changing-your-scooter-gear-oil/
More guide will follow to busy with my wife  ;)
vachira
« Reply #7 on: December 17, 2013, 04:13:49 AM »
Oil screen might look like this. 8)
« Reply #8 on: January 16, 2014, 01:52:51 AM »
Very nice job w/photos and blog!
