Author Topic: KYMCO 09 XCITING 250RI SPEEDOMETER ODOMETER NOT WORKING/ IDLE STALLING AT STOPS  (Read 1761 times)
cp
HELLO TO ALL. JUST PURCHASED KYMCO XCITING  250RI 2009, FORUMS HAVE ALWAYS BEEN VERY HELPFUL, I APPRECIATE ANY FEEDBACK OR SUGGESTIONS ON THE SPEEDOMETER,AND ODOMETER NOT WORKING. IDLE LOW, STALLING AT STOPS. OWNERS MANUAL SAYS, THAT THE 250RI IS FACTORY SET. IS THERE A FUSE, OR A CABLE THAT RUNS TO THE SPEEDOMETER? THANKS FOR YOUR ADVICE. REGARDS, CP
« Last Edit: August 01, 2013, 05:16:24 AM by cp »
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
It sounds like a fuse.  Did you ask the seller when it stopped working?
PaulC
rb250
there is a speedo reset that is very easy
if you google it its real easy to do if you cant find it I will relook it up
my speedo didn't work the day after I purchased mine brand new
due to batt conection at the batt as I fixed that the speedo didn't work
my dealr was no help and I found it in no time on line
if im to late sorry man I didn't see the post or if its not that then my bad
