Author Topic: battery not charging?  (Read 1110 times)
bism45
« on: August 04, 2013, 05:09:06 PM »
hi all, my battery should be charging on my mxu 250, the lights show it is but keeps going flat after a few days and it is a new battery, any ideas ??
partyhut
  • imstilriden
Re: battery not charging?
« Reply #1 on: August 12, 2013, 01:08:50 PM »
check voltage accross battery terminals with switch off and with engine running. should show slight increase when running
if charging.  may be a hig resistance short to ground somewhere.  try disconnecting items one at a time over several days
to see if discharging stops.   I use a battery tender on mine any time not riding for several days.
scootenalong in
Soddy Daisy, Tennessee
MaryK
« Reply #2 on: August 12, 2013, 04:49:44 PM »
That is right.  The fully charged battery should read 12.5 volts.
Then at engine idle, it may be a bit lower but the voltage should increase with RPMs to 14.5 volts.
Be sure the scooter is on the center stand and the rear wheel is off the ground when you rev the engine to about 3000 RPMs.
That is fast enough.  The voltage should not go over 14.5 or it may damage electrical components.
scoot safely,
New Rider in 2010
2009 GrandVista 250
