Author Topic: headlight  (Read 963 times)
hoffray
headlight
« on: July 30, 2009, 12:45:57 PM »
how do you change a headlight on a people 150
Calothrix
Re: headlight
« Reply #1 on: August 13, 2009, 05:05:54 PM »
I can get you part of the way there.  Remove the screw below the headlight and the three screws in the black panel behind the headlight (below the "dashboard").  Remove the bolt on each front turn signal.  Gently pry with a screwdriver between the black panel and the front panel that surrounds the headlight.  Do this on each side, close to the outside (there are "clips" here that need to be undone).  The front panel holding the headlight can then be pulled away enough to allow you access to the headlight.  Good luck!
