Author Topic: i2012 kymco super 8 50cc 2t - beginning of mods  (Read 10511 times)
rdartua
« on: August 09, 2013, 03:30:40 AM »
Hi gents - newbie here. Just bought my Kymco - still in warranty
- and guess what: as soon as I brought it home it did not start. :-[
PO said he left it with just a little gas over the winter - but was able to start it for demo
I assume its the carb got gummed up - so I will try to take off carb to clean.
Any ideas?
On the modding topic:
The scooter is all stock - but cdi seems un- restricted.
I got my hands on Leo Vince gp exhaust and would like to exchange it with stock.
What other steps are required to take full advantage of the pipe?
Really appreciate any help on both topics.
Thanks guys.
Robert.
« Last Edit: August 09, 2013, 03:34:49 AM by rdartua »
keepsitreal
  • Veteran Newbie
Re: i2012 kymco super 8 50cc 2t - beginning of mods
« Reply #1 on: August 09, 2013, 05:57:30 AM »
That pipes a great start! I just got started on my super 8 too. From what I've read/heard/seen other than the actual restrictions getting that air a flowin has the biggest impact on top and bottom performance. The stock jet is 72 but most come with a restricted ?tiny#? jet. Look around on here to see what's working with your exhaust. Seems like most are in the 82-84 or 90-92 range. If they didn't derestrict at the shop then you'll have to throw the smooth boss on too.
I'm doing same exhaust and tryin an 84 jet. Sense I'll be in there already I'm gonna go ahead and throw in a molassi variator/rollers along with the smooth boss and new spring. As far as I can tell that's a good place to stop and get all that dialed. Check out a stage one kit from provo or scooter hospital.
Anyone know any other good parts places?
Have good scootin!
A-Ville Scooter Mafia Original 8 '01 *Some Honda?
Rollin Krispy Kreme ten deep at 3am. '03-'05 *Stupid fast Super 9
Gang disbanded '05 due to mass Super 9 impound!
Back in town scootin round on my new Super 8 502t
Pimpy1
  • Mo Hoes Power
« Reply #2 on: August 09, 2013, 01:07:25 PM »
The stock jet is a #82 so go up from there. The restricted jet that comes in the US mode is a #72. I run a #91 jet with a drilled out air box with no issues.
2011 Kymco Super 8 2t
2006 Kymco People 250
rdartua
« Reply #3 on: August 09, 2013, 03:08:51 PM »
Great - thanks guys for the response.
Also - stock exhaust comes with this  tube connected to reed valve to suck some fresh air in for unburned fuels re-circulation - I assume that goes as well?
As for the intake - should i stick with standard air box or a cone filter - which seem like a cheap upgrade (around $10-$15)?
What is the size of the filter to use as well as the tube that attaches it to the carb?
« Last Edit: August 09, 2013, 03:10:52 PM by rdartua »
rdartua
« Reply #4 on: August 26, 2013, 01:51:34 PM »
Pimpy1, wordslinger - Help!!!
A bit of a good news: Mounted Leo Vince GP, #90 jet and removed rubber insert from Air Box(Waiting for K&N style filter from Scooter assassins)
And WHOA - different machine altogether - hills where I dragged at 12-15mph - I am blowing through @ 32mph and 45mph flats- and thats with the restricted clutch - which I am about to change.
If before I was kind of bogged down that I did not go for SR50 - now I know I made right decision.
Well that's for the good news:
Today in the morning - it just would not start at all - I spent 10 mins trying to start it  - nothing...
I opened crab drain bolt and and gas came out - so I know it gets to carb. - Am I running rich? should have waited for that new Air filter? (PS - I am running Iridium plug)
Guys - any suggestions would be greatly appreciated.
Rober.
« Last Edit: August 26, 2013, 02:12:28 PM by rdartua »
Pimpy1
  • Mo Hoes Power
« Reply #5 on: August 26, 2013, 09:04:58 PM »
Is the battery dead? That scoot will not even kickstart with a dead battery.
rdartua
« Reply #6 on: August 27, 2013, 02:26:14 AM »
Battery is perfect - I got it started - by restricting air flow to intake....so I assume I am running lean on the low jet??? - any way to adjust it. There is no low jet mixture screw on our Carburetor.
P.S. Thanks for answering.
rdartua
« Reply #7 on: August 27, 2013, 04:09:15 PM »
Guys - do we need a mixture screw? And how do we make it happen?
Pimpy1
  • Mo Hoes Power
« Reply #8 on: August 27, 2013, 09:22:11 PM »
There is not one on that little carb. need new carb for better fine tuning. Sorry.
rdartua
« Reply #9 on: August 28, 2013, 02:17:05 AM »
Actually according to Complex - in his post and with PM to me - he reiterated that there is a screw hiding behind that copper plug  - which does not have a slot to turn it with a screw driver.
However you can make that slot with hex saw once you open up that copper cap. Though in my opinion Dremel would do the trick.
Just as a curiosity - which aftermarket carb would better fit our Kymco?  - and how would we benefit? - Something that would work for original 50cc and 70cc bbk?
« Last Edit: August 28, 2013, 02:19:56 AM by rdartua »
complex
« Reply #10 on: August 28, 2013, 08:38:12 PM »
Its the hidden Idle screw   I had the same experience    I had to restrict air flow to get it started   Once I did the stock carb mod it started and idled each time.   If I leave it for several days it does take longer to start but otherwise perfect.   Here is a post I just left for someone else:
"I have a 2012 Super 8 2T.  27 MPH out of the crate.  I let it get 99 miles on the clock, did a lot of homework and luckily got it right after some minor wasted efforts.  Stop wasting your time and get the Malossi 70CC kit.  It needs this modification to get the power and speed.   It was easy to put in, about 1 hr.   I increased my main jet to a #95  and put a high volume air filter/boot.  I also used an EBay $30.00 racing variator and smooth bushing.   I now get 40 MPH easy and have had it up to 54 MPH tucked on the expressway.   I did have to pop the protective blank Idle Jet Cap and adjust it to have it start easily and idle.  That's it!   See my other Super 8 posts for carb mod pics.  The speed mainly came from the Malossi and stock carb mod
My son uses it daily for school and loves it.  600 miles on it so far"
2012 Kymco 300i
2012 Kymco Super 8 50T
2010 Honda Sh150i
1999 HD Fatboy/Heritage
rdartua
« Reply #11 on: August 29, 2013, 02:49:15 PM »
Thanks Complex.
I do get it to 45 pretty easy with 49cc - with lots of power throughout the acceleration range - I will keep it as is for now - unless there is a great deal on Malossi kit - which should be over the winter. just for that before storing I will pop the engine with rear wheel off - and leave it in my project room.
I tried adjusting the high jet using free-wheeling technique described here: http://scooter.wikia.com/wiki/Tuning_a_carburetor
Loud as hell - not sure I was successful - however after adjustment I started getting this annoying Resonance sound above 30mph. - anyone know what it is? Maybe its the issue with Reed valves?
Thanks,
Rober.
245luigi
  • Boston, MA
« Reply #12 on: August 29, 2013, 03:13:28 PM »
Some issue when I removed the airbox restriction; bike would not start cold. Ive put it back in till I get the proper idle jet
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
rdartua
« Reply #13 on: August 29, 2013, 04:22:47 PM »
What jet size would be proper? and do you really need it if you do idle mix screw mod?
Pimpy1
  • Mo Hoes Power
« Reply #14 on: August 29, 2013, 04:25:50 PM »
Thanks,
Rober.
I am getting a fairly loud cavitation type sound on my Super 8 2t and a bit of vibration around 35 and up. I have yet to find the issue.
