Author Topic: Maintenance tips - sliders vs rollers, valve adjust, new tires  (Read 6300 times)
scuba1065
I went to go ride last week and realized my rear tire was worn through to the threads. So, I went to the local motorcycle shop but was told, "they don't work on scooters."
It gave me another opportunity to play with the scooter. In doing so, I learned a few things that I thought I would pass on.
I replaced my tires with Michelin Pure SC's from Amazon.com I spent $115.00 to purchase them and took them out of town to have them mounted/balanced to the wheels. ($50.00)
To remove the wheels was extremely easy. Took about 1 hour to remove them and another hour to put them back on. (would take less time if I didn't read each step of the way to make sure I was doing it correctly.) They ride and look great. It fixed a bounce I was getting at deceleration with the old front tire.
While I had it apart, I set the valve clearance. I had a tick and realized that it was set at 0.03inch instead of 0.03 mm.  After reading other forums I decided to go with a thiner gap and gapped my valves to 0.03mm.  This fixed the ticking and it runs better. Thank you for those that posted videos on you tube on how to do this. It is really very easy, also described well in the users shop manual, also downloaded from a forum posting. Easy to find, A great tool.
I also replaced the belt and rollers. I went with motorscooterparts.com and was very happy with their service. The parts arrived quickly and as promised. I ordered the 1    O15-2286 - 894-23-28 Kevlar Belt - Gates Powerlink             50.99 and  1    U72-1787 - 23x18 Dr. Pulley Sliding Roller Weights             44.49. Very easy to install.
My scooter is well maintained as far as oil, I used to have it serviced by a scooter mechanic that is no longer in business. It has 9500 miles on it.
Also changed the oil, I elected to use 10W40. only 1 liter needed. Also very easy.
Running it today for a 100 mile trip: I have a GPS measured top speed of 80 (speedometer reads 87), up from 75. The acceleration is better, and it runs very smoothly. It's nice when everything works the first time.
Happy scooting.  :)
« Last Edit: August 11, 2013, 02:10:19 PM by scuba1065 »
windwheeler
    • WindStrom windshields
Re: Maintenance tips - sliders vs rollers, valve adjust, new tires
« Reply #1 on: August 11, 2013, 02:53:07 AM »
Hi Scuba,  a few questions:
What actual weight did you install for the Dr. Pulley sliders?  Same as the roller weight?
You used 0.03 mm for intake and exhaust valves? How do you come up with that? That's too tight!  Factory specs is 0.1mm, you are 3 times tighter...  You can burn a valve up-hill or wide open throttle, or if the clearence wears any tighter.  You need to fix that ASAP!
The 80 mph is that a one time max speed, or can you reach that flat out every time?
What is your gas mileage?
« Last Edit: August 11, 2013, 03:09:59 AM by windwheeler »
scuba1065
« Reply #2 on: August 11, 2013, 02:08:14 PM »
I put the same weight sliders, I read about putting in 18 to 22 but decided 20 gm was a good starting point. I'm really just looking for reliability.
My valves were set at the 0.1mm setting recommended and it was too loose. I realized that I could have been interpreted as giving bad advice here - just my experience. It runs better than ever at this setting and the settings came from reading the forums here and other places. I just spent another 80 miles on it this morning and at pretty close to WOT and 80 degrees, the engine ran cool and very well. I do appreciate the advice and will keep an eye/ear open for signs of trouble. I will fix my entry if I can. Good catch.
the 80 is down hill with no wind. However the flat out max speed is around 75 and stays that way up most hills. There is not as much speed loss that I was seeing with a belt that had 9500 miles and the rollers.
I will say that the belt I removed was still in spec and looked very good. When I removed the casing, my drive area was clean except for a slight amount of rubber dust, nothing like the guy that had his belt shredded. (another recent forum entry)
windwheeler
« Reply #3 on: August 11, 2013, 03:53:11 PM »
I am sorry, but 0.03 mm valve clearance is just too tight, no matter what.  You will not notice ANY problem until it is too late.  KYMCO posts its clearance on all 250 cc engines at 0.1mm, and whoever wants to reinvent the wheel with 0.03 not good... (maybe for racing, then it is a totally different story!)  Valve clearances get not always wider, they can get tighter, and then you will not know when you have  0.02 or 0.01? Too late; burnt valve(s), bad idle, loss of compression... don't do it.  Minimum 0.07mm would be my recommendation.  A valve rattle starts usually over 0.12mm and more.
You changed at the same time your roller weights to slider weights; this is responsible for your now higher top speed.  The sliders drop the rpm: e.g. at 75 mph you ran 8000 rpm with roller weights, or with slider weights at 75 mph you turn now around 7000 rpm . Your engine doesn't really make any much different power, but you used/adjusted with the Dr. Pulley's your transmission to make most out of that engine power.
I did extensive transmission setting testing with all kind of roller and slider weights. I ended up with 18g Dr. Pulley slider weights as the best benchmark performance (means factual and measured). My Grand Vista runs now GPS verified 77-78 mph flat out, and up to 83 mph down hill; original KYMCO valve clearance specs.   ;D
« Last Edit: August 15, 2013, 07:25:45 PM by windwheeler »
« Reply #4 on: August 11, 2013, 04:48:46 PM »
Gotta agree. You will not notice a difference with too tight valves other than tapping noise going away. Valves tapping a little is a happy sound.....silent valves are bad news.
Not many engines require valves adjusted these days - but I drove and serviced my aircooled VWs for 4 decades - you do not want tight valves!
Adjust them in a cold engine (sitting overnight) and to factory specs - not 1/3 of factory specs! You will have a silently ticking wallet buster if not set with the proper gap.
windwheeler
« Reply #5 on: August 11, 2013, 09:42:40 PM »
I'm just thinking, 0.003" (inch) would be "OK", 0.03mm is too tight.  You are not mixing up units and decimals here, right?
BTW: measured on my newer Grand Vista and the valve clearance is tightening up after 4000 miles on the odometer, especially on the exhaust side, where is even more crucial. I re-adjusted.  So, if that is the general rule, then you have, as Stig said, with 0.03mm "a ticking valet"..!   ;)
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
« Reply #6 on: August 14, 2013, 05:46:11 AM »
... mounted/balanced to the wheels. ($50.00)
I also replaced the belt and rollers. I went with motorscooterparts.com and was very happy with their service. The parts arrived quickly and as promised. I ordered the 1    O15-2286 - 894-23-28 Kevlar Belt - Gates Powerlink             50.99 and  1    U72-1787 - 23x18 Dr. Pulley Sliding Roller Weights             44.49. Very easy to install....
Wow you spent $50 on a Kevlar belt!  I only spent $85 on stock belt from my local dealer - ouch for me.  Wow, you spent $50 to have the tires mounted on the rims!  While I only spent $95 at my local dealer (just for the mount and spin) as I brought just the wheels and tires in.  The dealer said they charge by the hour to mount and spin so the price is not fixed!  Ok, I'm done with my local dealer.  I will order the sliders from motorscooterparts.com.  Great info and updates.
Do you have the link for the valve adjustment video?
For oil I get the 1 gallon of Delco 15w40 (4 qt) jug at wal mart for ~ $12.
Thanks for that informative post - hope it gives other scooter owners the courage to save $$ and do some or all maintenance.
Paul
PaulC
mrbios
« Reply #7 on: August 14, 2013, 05:53:09 AM »
I have 10,100 miles and I changed the original oem belt tonight with a new stock oem belt.  I had the same results - almost no dust, all components looked good.  Clutch looked great too.  My sliders have ver slight flat spots and I will replace them shortly.  When I turned the belt inside out and bent it back there were no cracks or dry rot.  The only thing I saw is that the belt left marks where it slapped against the bottom of the metal cover between the two pulleys.
This will be my first valve adjustment since buying the scoot 2 years ago with 2,600 miles I know I'm overdue.
« Last Edit: August 14, 2013, 06:01:11 AM by mrbios »
PaulC
mrbios
« Reply #8 on: August 14, 2013, 06:06:52 AM »
Can you recommend weights.  I'm interested in reducing my highway rpms.  I run 65 to 70+ mph.  I don't care if it reduces the acceleration.  Btw,  I average 55 mpg - that's with the tallest givi windshield and largest givi trunk / top case (I had to make an adapter out of wood).  Stock windshield I got 58 to 60.  I find high speed on the highway hurts the most but that is live in San Diego.
-Paul
2005 GV 250 w/ 10K mi.
PaulC
windwheeler
« Reply #9 on: August 14, 2013, 01:25:08 PM »
Paul, after all my testing the Dr. Pulley Slider Weights at 18 grams are the best compromise, and it will drop the rpm to 7000 rpm at 70-75 mph.  If you have standard roller weights you will see an improvement.  You can go to 20 g Dr. Pulley weights for a bit less rpm "in the middle" but you will loose acceleration.  Your gas mileage depends on that big windshield that is a barn door to push, and yes, I loose also mph and mpg when I have it on it in winter.
Eric
-Paul
richard1958
« Reply #10 on: August 14, 2013, 07:37:06 PM »
I'm confused.  I would like to be able to order parts like belts etc. so I tried the link motorscooterparts.com and it looked like that name is now available to buy.  Their were some "related links" listed below the message "Click here to buy motorscooterparts.com for your website name".  Below it were some links entitled "Related links".  Are one of those the one where parts can be ordered for Kymco scooters?  Thanks in advance!
windwheeler
« Reply #11 on: August 14, 2013, 08:16:58 PM »
Yeah, that's just a stupid self proclaimed site (they want to sell that domain name to others).
Are you buying otherwise on e-Bay?  There you can get all the parts.
Or, type into search engine "Dr. Pulley Slider Weights  Kymco 250" (23mm x 18mm and the weight you desire, either 18g, 19g,  or 20g) and it should give you several parts suppliers, where you can also get the belt.
BTW:  the belt width must be in minimum 23mm (OEM is 24.5mm); Kymco says" "Service belt if less than 22 mm) Some aftermarket belt suppliers are narrower new; I had to send a Gates belt back because it did not match the printed specifications.  I ordered a OEM Kymco Belt for my old G/V, and found a "price deal" for the new one on a Malossi belt that's supposed to be top of the line.
« Last Edit: August 14, 2013, 08:33:23 PM by windwheeler »
richard1958
« Reply #12 on: August 15, 2013, 05:28:23 PM »
Thanks Windwheeler.  I can see from reading this forum that there is a lot to the belt and slider selection.  My Grandvista 250 has around 4500 miles on it but it is a 2009 model, so the belt is probably getting old due to age more than mileage.
Rich
ophelia
« Reply #13 on: August 15, 2013, 07:02:08 PM »
My Bet and Win 250's valve clearances were dead on at 15000 km, but it doesn't take much work to stick a feeler gauge in and check.
Have a look at the belt if you have the tools (wrenches, sockets, mallet, cheap caliper) to do so. My 2008 B&W 250 belt was merely worn down to service limit at 20000 km, but it was in otherwise perfect condition; no rot, no fraying. No point in replacing a good belt.
2011 Kymco Downtown 300i
windwheeler
« Reply #14 on: August 15, 2013, 07:22:26 PM »
I agree, I would not replace a belt at 4500 miles.  The wear depends how "hot" the belt gets.  Interstate riding is harder on the belt than just around town with lower speed.  So, I would "inspect and measure it"; belt width should be above 22 mm, and no big signs of rubber shaved off in the casing.  I bet you have none of this.  I changed a belt at 11,500 miles because it started to slip, and that was my former 2005 G/V, and I ride a lot of interstate miles always around/above 70 mph GPS...
