Did you miss your
activation email
Scooters - 50cc
Ignition Coil
Topic: Ignition Coil (Read 1150 times)
Kenho21
Sr. Member
I live my life 0.402336 kilometers at a time
Ignition Coil
July 30, 2009, 07:36:20 PM »
I was recently changing my spark plug and I pulled the wire out of the cap that goes on top of the spark plug. It left a screw exposed which I just pushed back into the wire. Is that supposed to come off? I don't see a spark anymore but it I may have just not saw it I'm gonna check again when I get home.
Shaka
Re: Ignition Coil
July 30, 2009, 09:52:55 PM »
The spark plug cap just screws onto the coil wire. It has a pin down in there that is threaded. Just screw the cap back onto the coil wire, making sure that the pin goes into the center where the wires are. If you are questioning whether it is working. It is real easy to get a voltmeter and test. I could look up the proper specs if you need.
Kenho21
Sr. Member
Re: Ignition Coil
July 30, 2009, 11:26:02 PM »
I got it handled it, I think the problem was too large of a jet in the carb. I put the old one back in and it seems to be running fine. I think i just couldn't see the spark because its small on those little plugs, Lol.
Much Thanks,
Ken
Back
