Author Topic: handle bar cover removal  (Read 1211 times)
boo
« on: August 11, 2013, 03:24:21 PM »
For those who have removed the handle bar cover on the GT, how did you get the mirrors off?.
I have many sockets and cannot find one that will fit in the hole where the mirror nut is.
Also, does the mirror nut/bolt have right hand threads?.
300GTI black
Pro 2A - member GOA & NRA
ScooterCommuter
Re: Re: handle bar cover removal
« Reply #1 on: August 11, 2013, 03:53:40 PM »
If it's anything like the setup on the xc500, you may need to modify a socket. I needed to tighten the nut and while I had a mini-socket that would fit the nut, the recess in the mirror stalk was too small to fit the socket around the nut.
I fitted the socket into a drill chuck and held a file against it until the socket was slimmed down enough to go into the recess and grip the nut. If you can find a tool store that still sells box wrenches in that size instead of having switched completely to selling sets of mini-sockets that would work too, because they typically are lower profile than sockets.
boo
« Reply #2 on: August 11, 2013, 05:24:49 PM »
Thanks for the ideas.
I had already ground a socket to fit the mirror holding nut. When I try to loosen it, it feels like both ends are turning so I stopped.
Was afraid I might screw something up.
Got to wondering if it had left handed threads.
I noticed in your picture the mirror was still in place with the cover removed. Wish I could do that with the GT as all I want is to have access to the brake resivoirs
300GTI black
mnpugdog
« Reply #3 on: August 11, 2013, 06:50:34 PM »
The tools that came on my DT worked just fine for tightening the Mirror.
boo
« Reply #4 on: August 12, 2013, 04:51:31 PM »
No such tool in my pouch. boo
300GTI black
