Author Topic: Engine rattling louder at 400 kms  (Read 895 times)
wheelsoffreedom76
« on: August 15, 2013, 03:11:13 AM »
  I have a 2013 Agility 50 with about 430 km on it. I have done two oil changes (filter screen is clean),  and checked the valve clearance. The top end is oiling well, and the timing chain has tension on it.  I have pulled the cvt cover and checked for any loose parts, or bearings (even ran it with cover off to further examine). Upon cold start of morning it sounds about right. Once it warms up it begins chattering in the engine, and today it seemed to get a bit louder. It seem to be coming from the crankcase/cylinder area and since only the big end of the rod is pressure lubed I'm thinking it is the culprit once the oil gets hot and thinner. I am running rotella 15w-40 oil. I took it by the dealer (reluctantly) this afternoon and the salesman listened to it and made an appointment for next week to check it out. (There mechanic is horribly uneducated in all things I have dealt with them on). While warranty should cover this, I am concerned about their goofball tech screwing things up worse, especially if he tries to replace the crank or etc. I am a auto mechanic, anjd comfortable working on it myself, and am considering just tearing it down , and replacing whatever is failing, maybe upgrading performance too.
      Your thoughts on any weird problem I'm missing, and have any of you thrown your warranty out to do your own repairs?
phatboy
Re: Engine rattling louder at 400 kms
« Reply #1 on: August 15, 2013, 04:26:24 AM »
An exhaust leak can sound alot like engine noise, if its where the pipe connects with the head.
Also could it be detonation/ knocking you hear.
Mine makes a lot of vavle noise when warm even tho its at 0.003. I blame it on the a9 cam but maybe it was there before and I didn't notice.
« Last Edit: August 15, 2013, 04:28:28 AM by phatboy »
Agility 50 w/72cc BBK, A9 cam, stock airbox and exhaust (both drilled out), remove air tube restriction, stock head, stock carb, 105 main jet, CDI cut, smooth variator boss, stock variator w/5g rollers
wheelsoffreedom76
« Reply #2 on: August 16, 2013, 11:39:05 PM »
 I had checked the exhaust for leaks and loose mounting nuts. I also checked both inner and outer valve springs when I pulled the cover again yesterday to reexamine the cam/rockers and timing chain and tensioner. I got a mason jar and dropped the oil again (60 km since last change), and pulled the screen again, and still not a single spec on the screen ( none of the previous oil changes showed anything in the screen either). Took the mason jar out in the sun and looked real close and has a very, very ultra fine glitter that is not steel as a magnet stirred in the jar did not gather anything. It has to be aluminum. With only 435 km it may still be particles from break in. All the research I have looked at shows the connecting rod is aluminum, with a steel cage roller  bearing in the big end, and machined steel journal on the crank. From the pics it appears the rollers do roll against the aluminum bore of the rod end and could be where it is damaged causing the rattle, and aluminum dust in the oil. Does anybody know if these ship in the crate with oil in them, or could the setup guy at the dealer have forgot to put the oil in till after he test run it? I know he was back there power braking, and full throttling the engine as I could hear it. I do subscribe to the hard break in philosophy, so long as there was oil in it. The dealer cant get it in till next week, and says they will have to tear it down and examine, which would be my plan of attack too, however he also said they have never had one apart, that they dont stock any parts, and that there would maybe be "some" warranty work! I may just have to do it myself, and eat the expense just to know it's done right and trust the scooter.
