Author Topic: Super 9 - Transmission Cover GASKET Missing  (Read 1960 times)
fabio
« on: August 19, 2013, 10:17:40 PM »
Hi
I've just bought a 2009 50cc Super 9 AC.....
The transmission cover gasket is missing.....and I'm struggling to find a replacement.....any ideas where I can get one (i'm in the UK)...or even if its necessary - would some "instant gasket" do the same job?
Thanks in advance
Fabio
« Last Edit: August 22, 2013, 09:30:31 AM by fabio »
Current Stable: Kawasaki GPZ500, Honda CB125TDC, Piaggio NRG MC2, Kymco Agility..................Previous Rides: Vespa ET2, Vespa GT125, Vespa PK125, Lambretta Cento
Re: Super 9 - Transmission Cover Missing
« Reply #1 on: August 19, 2013, 10:59:06 PM »
  if your tranny is the same as mine ( 300i downtown)  it is vented,.   and 1/2 of my gasket is gone , so I dont think it is something to worry about,.  order a new gasket from powersportswarehouse.com    install when ever,,
fabio
« Reply #2 on: August 20, 2013, 08:11:36 AM »
I wasn't too sure about using the kick start without it??
fabio
Re: Super 9 - Transmission Cover GASKET Missing
« Reply #3 on: August 22, 2013, 09:31:56 AM »
I'm struggling to find a gasket - anyone had any success with an alternative product, eg rubber strips or "instant gasket" ?
naughty lee
  • 64 mph and pushing
« Reply #4 on: August 22, 2013, 11:48:02 AM »
Make one. You'll need a cornflake box and a small toffee hammer. You'll find a guide on YouTube
fabio
« Reply #5 on: August 22, 2013, 12:45:11 PM »
Will this be enough on the Super 9.....I thought that it needed a rubber gasket....or is that not necessary?
ophelia
« Reply #6 on: August 23, 2013, 03:50:44 AM »
Does it rain often where you live? If not, then you might not need the gasket.
2011 Kymco Downtown 300i
fabio
« Reply #7 on: August 23, 2013, 04:36:21 PM »
I was assuming that it needed the rubber gasket to get the clearances right for the kick start etc??? or am I being overly concerned about no big deal???
ophelia
« Reply #8 on: August 25, 2013, 01:20:15 AM »
How thick is the original gasket? The bigger Kymcos that I work on have a very flat fiber gasket. Put the cover on and see if the kick start engages.
fabio
« Reply #9 on: August 26, 2013, 09:09:31 PM »
Ok - I've managed to sort it
The problem was more that onefold
When I removed the transmission cover the kick start mechanism was loose as well as the gasket being missing
When I fixed the kickstart mechanism the cover sat much better against the casing.
I took about 2 mill off the length of the cover locating pegs and the cover fitted nice and flush
Thanks once again for all you help
Fabio
(Next problem is a non-connected oil pump - I'll start this in another thread)
