Author Topic: 2012 Agility 50 Difficult to start lots of white smoke  (Read 1140 times)
Fluffy
« on: August 20, 2013, 04:55:31 PM »
Hi there,
My 2012 Agility 50 has just done 1200km and has started having real problems, the engine will only start and run with my hand partially covering the air intake - as soon as I take it off the engine stalls. As it is running I get huge plumes of white smoke billowing from the exhaust, as I accelerate, after around %40 throttle, the bike all of a sudden starts shaking violently. I have tried installing a new carb but still the problem persists.
Would be grateful for any advice, Cheers!
wheelsoffreedom76
Re: 2012 Agility 50 Difficult to start lots of white smoke
« Reply #1 on: August 21, 2013, 12:53:30 AM »
 I'd check the oil level, and check the oil for fuel. ( overfilled, or stuck float in carb, severe flooding)
Check the air filter and tubing for oil. ( could be ingesting oil)
Check the compression. ( will reveal broken ring/s, piston, or scored cylinder)
Two methods to determine oil contamination is to smell the dipstick, and also take a sheet of white notebook paper and drip a drop of oil from the dipstick on it and watch it for a minute or so. The oil will soak in a different size circle than gasoline will and can show if and how much contamination.
Also did this problem occur all of the sudden, or did it show any signs of trouble over time? Is the scooter stock or mod, and if so what mods?
White smoke is burning oil. It is either ingesting it through the intake, or it is getting past the rings due to broken ring/s, piston, scored cylinder or high level.
naughty lee
  • 64 mph and pushing
« Reply #2 on: August 22, 2013, 07:01:13 AM »
Blocking the air filter makes it run better you say ?
Sounds like perhaps someone has altered your air screw making it lean.
naughty lee
« Reply #3 on: August 22, 2013, 07:04:05 AM »
Taken from another thread
Prior to speed test
Removed spark plug, cleaned and gapped to 0.9mil and refitted.
Removed the air filter, washed it gently in a small bowl of gasoline.
Wrung it out gently. Dipped it in two stoke oil then wrung out the excess gently.
Refitted air filter.
took the bike out and got it hot.
It must be hot before moving onto the next stage !
With the engine running, Park the bike on its centre stand on a block of wood to lift the rear wheel.
Locate the carburettor on the left hand side if the bike.
There are two screws located close together on it.
The highest one ( and the largest) is the idle. The lower is the air.
Turn the upper one fully clockwise (this allows more fuel in and your engine speed should rise)
Next turn the lower screw fully clockwise (to block the air) then turn it counter clockwise one full turn quickly to prevent the engine from stalling.
Continue turning the air screw counter clockwise and listen to the engine revs. Your aim is to make the engine rev as high as possible. Small adjustments of a quarter of a turn work well here, pausing for up to twenty seconds between adjustments to listen to engine speed.
eventually you allow too much air in and the revs will start to drop. You will then have to turn the air screw back the other way.
adjustments at this point can be very small, as little as 1/8 th of a turn. Find the spot where the bike revs highest..THEN turn the air screw 1/8 of a turn clockwise ( this is important as it makes the mixture slightly rich)
It's unlikely the revs will drop, but if they do, it will be something of nothing.
(i turn clockwise in very, very small increments until I hear just the slightest drop in speed)
Now turn the upper screw counter clockwise until the engine rev speed falls back down to regular tickover level.
Your mixture and tickover are now set. If the bike stalls in future then just turn the upper screw an eighth of a turn until it idles without stalling
Bike was taken to an undisclosed location in North Yorkshire
An indicated 64 mph
I'm gonna try refitting the iridium plug and leaning out the mixture a tad more
It will be some feat to hit 65mph on a genuine 49cc scoot, but the target is now in sight!
