Author Topic: ORDER MY SLIDER WEIGHTS SATURDAY  (Read 6789 times)
feebleknievel
    • Kickin Country hITS
« on: August 26, 2013, 08:55:04 AM »
Dr. Pulley Slider Weight 20x12 for 250/300cc - 8 pack - 15g
Price: $44.95
https://www.buggypartsnw.com/
IF YOU ORDER FROM THESE GUYS PAY THE FLAT RATE SHIPPING...it wil be to you any where in the USA in 3 days .i've been using these guys for 3 years there a very good company :)
moparkid
Re: ORDER MY SLIDER WEIGHTS SATURDAY
« Reply #1 on: August 27, 2013, 02:42:34 AM »
Isnt your bike new? If so, why the slider weights? Im old school.....if it aint broke, dont mess with it until it is broke.
feebleknievel
« Reply #2 on: August 27, 2013, 08:35:50 AM »
yes it's a 2011 7654.0 on it just don't like rollers rather have sliders.understand the old skool but sometimes not being broke isn't perfect
boo
« Reply #3 on: August 27, 2013, 03:47:02 PM »
Curious as to why you chose the 15 gm over 14 gm ?.
Thinking about changing mine too when it is time to replace belt.
Cannot decide which weight.
300GTI black
Pro 2A - member GOA & NRA
moparkid
« Reply #4 on: August 27, 2013, 06:47:59 PM »
Since I am not a scooter expert I guess I'll need to research the difference between rollers and sliders and the pros and cons of each. Let me know how it goes....
feebleknievel
« Reply #5 on: August 28, 2013, 03:15:46 PM »
Dr. Pulley Sliders are a different style of roller and can be used with your stock variator. The unique shape offers a variety of benefits:
Sliders engage up to 20% faster than traditional rollers. They allow you to engage in higher gear ratios.
Sliders last longer with much less wear than rollers because they slide rather than roll (hence the name!). Rollers and sliders should be inspected annually (at minimum) for wear. Rollers are especially prone to developing flat spots that inhibit their ability to move smoothly. If this occurs, they should be replaced. This is one advantage of sliders, as they already have flat sides and are not affected by this wear as much as rollers.
feebleknievel
« Reply #6 on: August 28, 2013, 05:33:55 PM »
got em in today.install them tomorrow.weather permitting...get and early am start..:)
boo
« Reply #7 on: August 29, 2013, 03:27:08 PM »
Reason for choosing 15 over 14 ?.
300GTI black
« Reply #8 on: August 29, 2013, 10:29:50 PM »
  15  or 14 gram sliders,. 14 gram will allow higher rpm. at lower speed ,. 15 gram should be about the same as original rollers, at lower rpm. at higher speed you should have lower rpm.  I have not seen that much difference. over all,. I have about 15,000 km. on my sliders and I dont see any sign of wear,
feebleknievel
« Reply #9 on: August 31, 2013, 08:59:49 PM »
The larger weight size will add top end only when you are doing other upgrades to make up for loss of bottom or take off.
The same is true for lighter weights, if you go too light you will need to make up for the loss on the top end.
yes the 15 g gives me a lower rpm at higher speeds i do alot of club riding we ride long distance i usually ride 400 miles every sunday avg speed 75mph
« Last Edit: August 31, 2013, 09:02:33 PM by feebleknievel »
feebleknievel
« Reply #10 on: September 02, 2013, 12:56:19 PM »
ok added the larger weights less rpm on the top side did not loose anything on the bottom  still just as quick as it was before i've had others tell me the DT 300 to them has a quick start.i' have turned some heads on some Burgmans they didn't thing the DT was fast  im loving it im 5"11 305 and surprisingly it's very quick
Adept
  • Empaticus Maximus
« Reply #11 on: September 02, 2013, 06:32:22 PM »
Read the Dr. Pulley topic! I have written many experiences about 14 and 15gr rollers... I will try 16gr soon... :D
Don't start a new topic because there is a fine conversation...
I have a barely used (200km)14gr Dr Pulley rollers to SELL!! Send a PM if you interested in...
feebleknievel
« Reply #12 on: September 03, 2013, 04:37:05 AM »
i'll run these 15 for a while then try the 16's when i change the belt
boo
« Reply #13 on: September 04, 2013, 02:38:20 PM »
Link ?
300GTI black
8eeman77
  • Work hard, ride safe
  • I'm a scooter loving Apiarist
« Reply #14 on: September 05, 2013, 03:42:59 AM »
I went to https://www.buggypartsnw.com/
Which sliders are used for the DT 300i abs? Would my local scooter workshop know how to replace the rollers with these?
The Kymco DT 300i ABS is the best scooter you can get. I love it's carefree automatic ride. I would like to see kymco make a 600cc version but no heavier then the 300. I would buy it for sure
